This message is logs all event related to the MEP Fault Notification Generation state machine for debugging purposes.
This message is for debug purposes only, and should only be enabled on request of Extreme Networks Technical Support.
Debug-Verbose
[%port%/%vlan%/%type%/%level%]MEP Fault Notification event \"%event%\", state \"%state%\", someMACstatusDefect=%MACenable%, fngWhile=%fngWhile%, someRMEPCCMdefect=%rMepCCMenable%, someRDIdefect=%RDIenable%
| Name | Type |
| port | xInt32 |
| vlan | uInt32 |
| type | uInt32 |
| level | uInt32 |
| event | String |
| state | String |
| MACenable | String |
| fngWhile | uInt32 |
| rMepCCMenable | String |
| RDIenable | String |
